Front brake lines
Rocket
Front brake lines
Postby Rocket » Sun Sep 17, 2017 1:24 pm
Folks.
Advice please
1995 Mono R100RT with Brembo calipers (hoop link over front wheel).
Effectively I have made this into a flat tracker. As such I have arrived at the front brakes, I'm a little perplexed as the original brake line set up appears to head down to the front right caliper, over the wheel via link pipe and to the left caliper whereby the bleed nipple is located. However as it is now unfaired there's a lot of pipes on show and securing the pipe from the spine of the bike around the oil cooler looks to be a pain. My question is thus....
Can I use the master cylinder to supply braided lines down to the front calipers with a double banjo bolt? I'm guessing that this will provide equal pressure to the brembos resulting in each caliper being able to be bled separately.
If this is the case and with a set of standard slight rise bars can anyone point me in the direction of a ready made kit please? Someone must have done this way, way before me. Any help or links greatly received.
martinwR65
Club Member 12
Re: Front brake lines
Postby martinwR65 » Sun Sep 17, 2017 6:17 pm
I've done it that way a few times, works fine. Also cheaper as it's 2 lines instead of 3!
I'd be surprised if anyone makes a kit for that though, they generally do like-for-like to standard so as not to annoy the rules police. Just measure up using a piece of wire and order from one of the suppliers that does custom made lines to order.
Powered by propeller shoes, flying sub ahoy!
KHL100W
Country of Residence: No longer here
Postby KHL100W » Sun Sep 17, 2017 7:19 pm
*********Deleted**********
Rocket
Postby Rocket » Sun Sep 17, 2017 7:23 pm
Thank you. The T piece sounds like a plan. As you say it'll be a lot neater. Any ideas for lines as they appear unusual in that the connection at the caliper will need to be a bleed nipple type as opposed to a banjo?
martinwR65
Club Member 12
Postby martinwR65 » Sun Sep 17, 2017 7:30 pm
martinwR65
Club Member 12
Postby martinwR65 » Sun Sep 17, 2017 7:33 pm
...and I like HEL for custom brake hoses:
http://www.helperformance.com/custom-brake-hose
Rocket
Postby Rocket » Sun Sep 17, 2017 7:58 pm
Fantastic, thankyou,
KHL100W
Postby KHL100W » Sun Sep 17, 2017 7:59 pm
Rocket
Postby Rocket » Sun Sep 17, 2017 8:25 pm
Thankyou. Can I confirm they are M10x1.25 does anyone know?
KHL100W
Postby KHL100W » Sun Sep 17, 2017 11:18 pm
Rocket
Postby Rocket » Mon Sep 18, 2017 5:28 am
Lovely, thankyou
Users browsing this forum: No registered users and 8 guests
