R1200GS 2007
Country of Residence: england
R1200GS 2007
Postby iansparkykeene » Sat Jun 10, 2017 8:53 am
Problem with starting when engine is warm, turns over ok but wont fire , when running is perfect runs well pulls hard in all gears at slow and high speed suspect fuelling issue or sensor broke down at channel tunnel returning fro Italy and had to be recovered. Open to all suggestions to try before booking into bmw agents or independent dealer in north west england
Re: R1200GS 2007
Postby Galactic Greyhound » Sat Jun 10, 2017 10:11 am
It could be running too rich so won't fire up easily when warm.
You might try disconnecting the exhaust Lambda sensor which only comes into play when the engine is warm and varies the air/fuel ratio.
Disconnecting the sensor will cause the ECU to use a fixed default fuelling map which will provide a fixed fuelling when the bike is warm.
A faulty Lambda sensor might be varying the fuelling incorrectly so that it is too rich and the bike will not start when warm.
You may get an alarm/Fault Code when the Lambda sensor is disconnected but the bike should run on the ECU default setting OK.
Club Member 12
Re: R1200GS 2007
Postby Ruralman » Sat Jun 10, 2017 1:17 pm
Sounds like the lambda sensor
Sent from my iPhone using Tapatalk Pro
Club Chairman
2006 R1200GSA
2004 K1200rs
'Live to ride - ride to live'
\:D/ \:D/ \:D/ \:D/ \:D/
Re: R1200GS 2007
Postby iansparkykeene » Sun Jun 11, 2017 9:09 am
thanks for the advise guys I will check this out
Re: R1200GS 2007
Postby P-K » Mon Jun 12, 2017 10:21 am
Moved to here from BM riders club general chat.
Likely to get more responses on here
''93 R100GSPD : '17 R9T Urban G/S : '12 R1200R
