K75 ABS removed, does it cause speedo problems?
Quzzy
Country of Residence: france
Postby Quzzy » Fri Jun 01, 2018 9:59 am
Hi, Im doing some work on a K75 that has had the ABS bypassed, brakes work well, no problem.
However the speedo sensor on the rear drive has had the wires snipped...is this because the speedo relies on the ABS or just coincidence?
1987 K100
2002 RT1150
Re: K75 ABS removed, does it cause speedo problems?
Postby george baker » Fri Jun 01, 2018 11:26 am
hi
i dont know but believe you should not need the sensor cables to be snipped to remove the abs on a K75
Quzzy
Postby Quzzy » Fri Jun 01, 2018 12:27 pm
Thanks George, the question was badly worded....if I buy a new sensor(the wires are not even showing) and reconnect it, should the speedo then work? Or does messing with the ABS cause trouble. This is obviously the older model with a seperate sensor, the speedo signal is not from the ABS rotors.
1987 K100
2002 RT1150
Inge K.
Country of Residence: Norway
Postby Inge K. » Fri Jun 01, 2018 5:30 pm
On a K75 the speedo sensor is only a speedo sensor and have no connection to the ABS system.....that was on later models.
Quzzy
Postby Quzzy » Sat Jun 02, 2018 8:04 am
Thanks.....hmm, I wonder why it was cut?
1987 K100
2002 RT1150
