Fairing parts "well nuts"
andymcg
Postby andymcg » Sat Sep 01, 2018 11:28 am
I am trying to reduce the wobble on the fairing on Walter my 30yr old K75s.
I have removed the fairing and have found that some of the plastic (nylon?) expanding insets have split and fallen out. Well past design life I guess so no complaint.
They seem to be available from Motorworks part no FAA51393 but they want £1.20 each!
they can only cost a few pennies to make, I wonder if anyone has found a cheaper source or has a bag of them!
Can't order till Monday anyway so thought I would ask. Local motor factor doesn't have them. Ebay shows lots of the round rubber type but not these ones that go in a square hole.
seehttps://www.motorworks.co.uk/vlive/Shop/Parts.p ... 0&spPage=2
I know it is silly to quibble about a few quid but it is annoying to see a small cheap part that is apparently so over priced. I suppose it is what it does, not what it is you pay for!
It's not grim up North!
since 1994 a R100R and from Oct 2015 "Walter" K75S, and from Aug 2016 R850R!
Re: Fairing parts "well nuts"
Postby Galactic Greyhound » Sat Sep 01, 2018 1:23 pm
Hi Andy,
The price also reflects that the item has to be purchased, stocked and put on the website for what might be a low-turnover item but is stocked as a service to BMW owners. :smile:
andymcg
Postby andymcg » Sat Sep 01, 2018 2:56 pm
Fair point.
In fact another of the local motor factors “though he had something like that in the back” sure enough he returned with a very similar plastic plug and I got 4 for a pound (no receipt)
One of bolts holding headlamp bracket to the centre support was missing. Replaced and fairing much more solid now!
andymcg
Postby andymcg » Sat Sep 01, 2018 3:01 pm
Local factor showed me catalogue from
https://www.connect-consumables.co.uk/
They have an amazing range of trim clips etc often in bags of 50 though.
May be of use for some parts.
