I found this little gadget... what I liked about it is that is tests the alternator as well as the battery...
I have the Optimate 3 on my K1300GT and this just clips onto the same lead - so no need to even disturb the battery when checking. =D>
https://youtu.be/PlaOewU0g_U
Dave
Optimate Battery and Bike Tester
- Country of Residence: Ireland
- Rob Frankhamr
- Club Member 14
Re: Optimate Battery and Bike Tester
This is just a LED linear voltmeter. You can do the same test with a digital multimeter for a third of the cost and do a lot more besides...
The other thing is that the video is wrong. This doesn't test the battery's cranking power (just it's voltage during a start, which is notwhere near the same thing) or really it's health (which is it's capacity to hold charge). It shows voltages under various very limited conditions and that's all.
I love it!
I also posted the wrong version of the video which did not include the testing of the charging system.
Here is the correct version
- Rob Frankhamr
- Club Member 14
I gathered you were impressed...
Unfortunately, I would still say that it is overpriced and tells you nothing that you can't see from a simple DVM which you can pick up just about anywhere for a tenner. The DVM will also give you a whole host of other functions involving vehicle electrics, mains and low voltage battery systems. I tend to carry a small DVM when I'm going any distance and this item wouldn't tell me anything more than I could tell from that.
Last edited by Rob Frankhamr on Wed Dec 09, 2020 11:32 am, edited 1 time in total.
- DEEP DIVER
- Country of Residence: ENGLAND
At work we used clip on amp meters to measure amp charge and starting draw, like this type. You just clip them over any of the battery cables on a straight part of the cable . And a DVM to measure volts.
https://www.ebay.co.uk/itm/Durite-0-534 ... SwOd9duB~X
1985 R80ST being rebuilt
1985 R80RT Touring dream sold
2 Harley sportsters being rebuilt
And a VW trike so I don't fall off
Thsi is what I use for measuring big current:
https://uk.rs-online.com/web/p/clamp-me ... %3Atrue%7D
- DEEP DIVER
We used them on the electric fork trucks to check the drive motor current. But a bit big for a motorcycle.Thsi is what I use for measuring big current:
Ah, yes. The resolution aint much cop for small currents but with thin wires I just wrap the wire round the clamp then divide the result by the number of times I went round. :)
Fair enough - each to their own! =D>I gathered you were impressed...![]()
UInfortunately, I would still say that it is overpriced and tells you nothing that you can't see from a simple DVM which you can pick up just about anywhere for a tenner. The DVM will also give you a whole host of other functions involving vehicle electrics, mains and low voltage battery systems. I tend to carry a small DVM when I'm going any distance and this item wouldn't tell me anything more than I could tell from that.
