Run n buff silver leaf on forks
Dode4444
Postby Dode4444 » Fri Nov 16, 2018 7:58 am
I’m planning on trying to clean up the fork covers (unsure if that’s the proper name or not) on my R1150RT.
They seem to be a common problem and get bubbly and corroded from what I’ve read on here.
Just had a few questions though please.....
As I’m not entirely confident on how to remove these can they be cleaned up and painted on the bike.
Do you just use n abrasive pad etc, sand the worst off and paint the rub n buff on?
Any help would be appreciated, thank you folks.
Dode4444
Re: Run n buff silver leaf on forks
Postby Dode4444 » Thu Nov 22, 2018 7:43 am
Anyone have any advice?
oldyam
Country of Residence: Ireland
Postby oldyam » Thu Nov 22, 2018 11:19 am
Yes you can refurb them on the bike, just mask off everything else.
I would clean off any loose and flaking paint and then continue till you have a smooth surface to paint onto.
Then I would use either a rattle-can in your chosen colour then laquer over the top or Hammerite smooth, possibly try laquer over that too but try it on something else first as I have never laquered over the hammerite.
Nigel
1994 Triumph Trophy in British Racing Green
1993 Triumph Trophy in Caspian Blue
1999 Triumph Trophy in Oxford Blue
2007 R 1200 RT Blood Bike Leinster
2000 R 1100 RT in Black ( Sold )
1981 Yamaha XJ650 in Red ( Sold)
c13pep
Postby c13pep » Thu Nov 22, 2018 2:53 pm
Having replaced the forks on my RT for the very same reason (originals had all over corrosion and pitting) I can advise that removing forks would make the job a lot easier. The main point is that fork removal is straight forward and easy once plastics are off and it also exposes other potential corrosion that can then be `doctored`. I intend refurbishing my old forks but was advised that vapour blasting the aluminium lowers would be the best way to go and then possibly powder coating or stove enamelling, but it`s not now urgent so will wait while funds recoup from Xmas [-o<
CHRIS
you can`t have any fun in a straight line
R1150RT
MOTO GUZZI MONZA (project)
tigcraft
Country of Residence: Holmfirth England
Postby tigcraft » Thu Nov 22, 2018 8:52 pm
Rub n buff is just like shoe polish. It’s a quick fix to brighten up things that arnt in your face. It sticks best to porous surfaces which is good for castings. It the sort of stuff to tie you over.
Dode4444
Postby Dode4444 » Fri Nov 23, 2018 7:33 am
Thanks for the advice folks
silverrider
Country of Residence: Newcastle upon Tyne
Postby silverrider » Thu Feb 07, 2019 11:13 pm
Did you use the rub and buff silver leaf ?
Im thinking ill try it on my lower leg front forks.
Cheers
Postby milleplod » Thu Feb 07, 2019 11:47 pm
I used it on the lower forks on my 1200RT - they came up a treat, for very little effort. I applied it with a toothbrush, quick buff up with a cloth, they look good again! :smile: Not sure how long it'll last, but it only took 10 mins so re-doing them is hardly a graft. I got mine for around £6/7 delivered on Amazon.
Nocto Diuque Venamur
silverrider
Postby silverrider » Sun Feb 10, 2019 12:39 am
Result !
Thanks....im thinking the finish on my rt will be the same as yours?....were they marked through riding through the winter ?
silverrider
Postby silverrider » Sun Feb 10, 2019 8:52 am
(Sorry i should have said i have a 2001 1150 RT)
