R1100S Rear master cyl repair kit
Big G
Postby Big G » Fri May 14, 2021 1:16 pm
Hello everyone, I have a 03 R1100S with a leak from the rear master cylinder, does anyone know if there is a repair kit for this, I know Motoworks can supply a new one but a seal kit should be a lot more economical.
Cheers,
Gary
Re: R1100S Rear master cyl repair kit
Postby Jaythro » Fri May 14, 2021 10:10 pm
Unless you can find a brembo or Magura kit for it
I think your luck is out
https://www.realoem.com/bmw/enUS/partgr ... g=34&sg=31
Mark Esposito
Postby Mark Esposito » Fri May 14, 2021 11:59 pm
Oops sorry found caliper kit not master cylinder kit
Mark
I have a 1988 R80 RT monolever in case i forget to mention it when asking a question ! and I'm based in South Wales
Postby Rob Frankhamr » Sat May 15, 2021 10:15 am
From BMWs parts lists, it looks as though they never have supplied a kit of parts for that master cylinder. If it can actually be dismantled, you might be able to source seals that will fit. The other bad news is that none of the three 'usual' suppliers... Motorwoks, Motobins and Sherlocks, seem to supply a replacement 13mm cylinder for your model. It's likely that the 12mm cylinder from other R1100 models might fit or the 13mm cylinder from the GS but they have different numbers so you'll need to check.
Big G
Postby Big G » Sat May 15, 2021 10:45 am
Ok Rob, thanks for the reply, i haven't had a good look to see if it will dismantle so that will be the next.
Cheers,
Gary
Big G
Postby Big G » Sat May 15, 2021 10:49 am
Thanks for the reply, looks like plan B when i have it !
Cheers,
Gary
Big G
Postby Big G » Fri Jun 18, 2021 1:51 pm
Hello all, quick update on my brake prob, got a 13mm Brembo from Ebay, it fit without any modification to replace the BMW one, just needed the length on the adjuster setting. Can know use the rear brake when needed.
Cheers,
Gary
Postby george baker » Sat Jun 19, 2021 12:35 pm
good news, did you find out what it was from?
Big G
Postby Big G » Sat Jul 03, 2021 2:44 pm
Hello George,
add didn't say what it was for just said 13mm and gave the hole centre for bolting it on. The Ebay number is ( 324302597945 ) its still on, have just had a look.
Cheers,
Gary
Postby george baker » Sun Jul 04, 2021 12:34 pm
Ta
