Considering airhead mono purchase
kent_instructor10
Country of Residence: Kent, UK
Postby kent_instructor10 » Sun Sep 13, 2020 10:13 pm
I am now in a position to seriously look for an airhead mono, preferably R80Rt or R100RT. Possibly a light restoration job, more on the cosmetic side as I have limited technical knowledge, especially airhead specific!
Is there anything I particularly need to be aware of and check out prior to purchase, and are there any pros and cons re different model years ?
Many thanks
Re: Considering airhead mono purchase
Postby george baker » Sun Sep 13, 2020 11:16 pm
Search around cos this question has been Asked before a couple of times
My Take ymmv
80s are a bit cheaper and less complicated twin disk, oil cooler, 100s have less gear changes so more relaxed to ride
Good luck with your search
Postby Rob Frankhamr » Mon Sep 14, 2020 1:21 am
There are very few differences in the Mono bikes from '85 to '95. I think condition and mileage are probably the only parameters you need to worry about.
Postby SteveD » Mon Sep 14, 2020 12:23 pm
When did the circlip return to the trans?
Doug504
Postby Doug504 » Mon Sep 14, 2020 8:26 pm
I purchased a 1989 low mileage R80RT approx 5 years ago. Mechanically it’s been sound, however I have had to replace numerous rubber parts due to deterioration of the rubber over time. These include gearbox to driveshaft boot, screen rubber seal, also replaced screen due to discolouration, Speedo cable to gearbox grommet, seal between fairing storage boxes and fairing, rubber clock surrounds. This year have done fork seals although no leaks from those in place and replaced jets and diaphragms using overhaul kits from Motorworks. The latter has resulted in a much smoother and responsive engine. Nice bike to ride and easy to maintain, I would suggest, as others have, go for the most original you can get with a low mileage. So many of these bikes are being butchered to make ridiculously priced “bobbers” that the price for original bikes are increasing but you can still get some good deals.
Postby DEEP DIVER » Mon Sep 14, 2020 9:32 pm
As long as they have had the correct service interval then a high mileage bike will be ok. This one is high but has been well looked after. Worth a phone call. I've only ever rode the R80 and found it very smooth I've aslo been told the R100 can be a bit rough? but try them first.
My 85 R80RT would ride all day 2 up fully loaded and is a great touring bike.
https://www.ebay.co.uk/itm/Lovely-BMW-R ... SwGL5fVKYy
Or
https://www.ebay.co.uk/itm/1988-BMW-R80 ... SwY-ZfRXdU
Now here is a nice R100
https://www.ebay.co.uk/itm/BMW-R100-RT/ ... SwblBfRlMM
Just remembered try and go for the non para lever drive shaft as they run in oil and I think it's better for lubrication.
1985 R80RT Touring dream sold
Postby DEEP DIVER » Mon Sep 14, 2020 9:49 pm
One thing to look for is the speedo cable boot in to the top of the gear box. Water runs down it and into the gearbox and mixes with the oil. Check if its got a tight new boot. If the gearbox bearings get water/ oil mix they will wear quick. If the gearbox sounds rumbly when warm pull in the clutch to see if the noise stops. A full set of 6 bearings is £119 from Motorworks, or rebuilt box £650.
And airhead engines are very easy to work on.
Re: Considering airhead mono purchased
Postby george baker » Mon Sep 14, 2020 10:05 pm
Hi I expect a
Yep 100s can be rough but also my 80 was better for my ride to work due to aa combination of speed limits, peek power and final drive ratio I think.
The 100 tempted me to go faster than the 80 ever did
Tony the Skin
Postby Tony the Skin » Mon Sep 14, 2020 11:53 pm
The R100RT I have is a 1995 model. Compared to the earlier bikes braking and handling are much improved. It is almost a KRT but with boxer engine.
BMW R75/5
BMW R90/S
BMW R75/7
BMW R100 RT Classic
BMW K75 Sprint
BMW R1200 RS LC
Harleys
Suzuki GT750A
Membership No. 672
Postby Rob Frankhamr » Tue Sep 15, 2020 9:58 am
On the subject of brakes...
According to the lists, the Mono airheads got the same front brakes as some K100 and K75 models from 08/88. Prior to that (between '85 and '88) they had slightly different parts but the leading dimensions are the same. The only other difference is that some bikes got fitted with floating discs. As far as the lists are concerned, these were exchange items and could be fitted to all Monoshock machines. It's not clear whether any airheads left the factory with them. The main difference between different bikes is the diameter of the master cylinder but there is no reliable information on which size each vehicle got... it seemed to vary between construction batches.
Airheads got the 'K' type front forks right from the start of the Monoshock production. There was a change in fork internals this is mainly around the securing of the top cap... springs and dampers remained the same... from 09/85 but from then on, they stayed the same to the end of production. The forks are based on those made for the 'K' bikes but they aren't the same and there are very few common parts.
kent_instructor10
Postby kent_instructor10 » Tue Sep 15, 2020 5:22 pm
Thanks all for your responses, much appreciated.
Users browsing this forum: Jojje, krankshaft, Mjolinor and 32 guests
