Tank repair / refurbishment
ValleyLad79
Country of Residence: Uk
Postby ValleyLad79 » Tue Sep 08, 2020 6:16 pm
Hello
Be gentle with me this is my first technical question.
I got a R50/2...
most of the work I can do myself. But I am a little nervous about repairing the tank.
On both sides the tank ( Schorsch Meier )got holders welded on for the knee rubber protectors.
The one side is rusted to bits that’s needs to be sorted.
Would like to get the tank lined or coated inside.
And the repair painted.
Is there any where close to South Wales a shop that offers it all?
Many thanks
Re: Tank repair / refurbishment
Postby george baker » Tue Sep 08, 2020 11:37 pm
I don't know and it's your bike now so up to you what you do with it but I would consider sticking the knee rubber on and keeping the out side of the tank paint original
Good luck with what ever you decide
Postby Mjolinor » Tue Sep 08, 2020 11:49 pm
I too would leave it as is on the outside but you need to make it cope with unleaded fuel with Ethanol so lining the inside is a must.
ValleyLad79
Postby ValleyLad79 » Wed Sep 09, 2020 7:41 pm
Thank you for the advice .
Any recommendations on rust stopper for the rusted part of knee pad holder bracket?
Postby george baker » Wed Sep 09, 2020 11:25 pm
Frost products are well regarded but I've never used them
ValleyLad79
Postby ValleyLad79 » Thu Sep 10, 2020 7:50 pm
I had a look and the internal colour is a reddish / orange .
I does have a few rust flecks in it.
What type of coating or paint could it be ?
chasbmw
Postby chasbmw » Mon Oct 19, 2020 7:04 pm
Reddish orNGE SOUNDS Good, and few rust flakes is not too much of an issue especially if you remove the taps and clean out the water etc that may be found there. I wouldn’t seal the tank unless you really have to, just use a product such as Fernox(?) to deal with any rust.
Charles
2016 CCM 450
1975 R90/6
1958 R50
2012 R1200R
