Digital Cordless Compressor
raesewell
Postby raesewell » Thu Apr 12, 2018 11:27 am
I have just bought one of these
It seems to be of good quality and has a sturdy feel. It's on charge at the moment, I'll test it out when it's charged and report back.
I got it from Ebay here
Ebay Click Here
Youtube review here (not mine)
https://www.youtube.com/watch?v=JoB44j8IFUI&t=329s
Mark Esposito
Re: RE: Digital Cordless Compressor
Postby Mark Esposito » Thu Apr 12, 2018 12:32 pm
Ebay Click Here
It looks good, please let us know how you get on with it, how long it takes to inflate a bike tyre , how many you can inflate on one charge, anything you like / dislike ?
Thanks Mark
Sent from my VFD 710 using Tapatalk
I have a 1988 R80 RT monolever in case i forget to mention it when asking a question ! and I'm based in South Wales
raesewell
Re: Digital Cordless Compressor
Postby raesewell » Thu Apr 12, 2018 1:13 pm
OK folks I have just given it a trial run. I totally deflated my rear tyre set the unit to 42psi and set it running, it took 9 minutes 10 seconds to fully inflate the tyre. It shut off when it reached the preset pressure. I checked the pressure with a calibrated PCL digital inflater and it was bang on 42psi the PCL measures tenths so I was pleasantly surprised with the accuracy. Although the air going in was warming up as we went on, so that would affect pressure and I will check it again later but it would certainly get you out of a fix. It didn't get overly hot in operation, the air tube was warm to the touch but not burning hot as some can be.
So it gets a big thumbs up from me.
raesewell
Postby raesewell » Thu Apr 12, 2018 1:34 pm
I have just performed a further test after the first rear tyre inflation and deflated it again and this time the battery gave out at 10psi
But I am happy at that, if it can inflate one tyre from flat that'll do for me.
It was £33.99 and that was one of the cheapest on Ebay there are more expensive ones, I don't know if the more expensive ones have a more powerful battery.
Postby Galactic Greyhound » Thu Apr 12, 2018 1:59 pm
Good testing info Rae!
When the inflator battery has been flattened, can the unit be plugged into a USB source and continue inflating a second tyre without being recharged?
raesewell
Postby raesewell » Thu Apr 12, 2018 2:22 pm
I don't know Ced and I have no way of testing that at the moment. I did read somewhere that it gets about 90% charge in something like 15 or 20 minutes.
Postby george baker » Thu Apr 12, 2018 2:27 pm
Hi Rae
good review. Tyre inflater and Torch combined which is useful. The one thing that is inside the box but not available is the option to use it as a USB power pack
I have a 12V starter unit with USB out which is good but there is a special connector so it is not easy to get at the 12V except with the crock clips, it would cost coppers to give us a lead with the connector on so you could access the 12V or even put an accessory socket on.
Mark Esposito
Re: RE: Re: Digital Cordless Compressor
Postby Mark Esposito » Thu Apr 12, 2018 2:33 pm
Hi Rae
They are available George, I have one with my starter kit.
MarkImage
Postby george baker » Thu Apr 12, 2018 2:37 pm
yep, but I can not find the connector in anyone's catalogue. I was given the starter battery as a present so did not get to choose the one I got
Mark Esposito
Postby Mark Esposito » Thu Apr 12, 2018 2:39 pm
Here's one from the UK, if you can wait for one from China they are cheaper.
https://rover.ebay.com/rover/0/0/0?mpre ... 3600533854
Mark
raesewell
Postby raesewell » Thu Apr 12, 2018 3:26 pm
A bit more info, it does not run while charging (I found a way Ced) and ignore the 90% in 15 minutes. It needs to be fully charged.
However all in all I am happy with the way the unit performs.
Postby george baker » Thu Apr 12, 2018 5:40 pm
Hi Mark
They look like the right one, are those connectors some sort of standard?
Mark Esposito
Postby Mark Esposito » Thu Apr 12, 2018 5:44 pm
Hi Mark
Hi George,
I think they call them DO or maybe OD connector because of the end on profile.
My brother has had two starter packs and both of his (different brands ) are the same as mine.
Mark
Postby Galactic Greyhound » Thu Apr 12, 2018 5:47 pm
Thanks Rae! :smile:
Postby george baker » Thu Apr 12, 2018 5:51 pm
Thanks Mark, I ordered a pair, let's hope they are a standard, they seem to be called Ec5
andymcg
Postby andymcg » Thu Apr 12, 2018 10:10 pm
Just wondering why you want a pump with the small capacity rechargeable battery when won’t you have access to more stored electricity in the motorcycle’s battery?
Or real old school how about a traditional bike pump!
I do have the CO2 cartridge system in the toolkit on my R100R but have never had to use them and am not sure if I could.
It's not grim up North!
since 1994 a R100R and from Oct 2015 "Walter" K75S, and from Aug 2016 R850R!
Postby windmill john » Fri Apr 13, 2018 8:07 am
I’ve got three of these, well similar with double head for push bike.
One on the push bike, one on Schorsch and one was under the seat of Walter and Friedrich; sorry Andy, kept it, I bought it!
I have used it to fully inflate a flat tyre. Pretty sure it didn’t take more than ten minutes.
Easy to store, no maintenance... and I could take it on a flight if so inclined :grin:
raesewell
Postby raesewell » Fri Apr 13, 2018 10:14 am
To answer your question, because I'm a big kid with more money than sense and I love gadgets. Also as I said previously, using tyre sealant means I haven't had a flat tyre in over 70,000 miles. Being a belt and braces man I like to have a backup just in case. I have the Bikers dream foot pump as well and they are both on the bike at the moment and I will retire one of them but as yet don't know which one.
You can't take your money with you so you might as well enjoy it while you still can.
I hope that clears thing up for you.
Mark Esposito
Postby Mark Esposito » Sat Apr 28, 2018 12:12 pm
Hi George,
Did they arrive yet and more importantly did they fit ?
Mark
Postby george baker » Sat Apr 28, 2018 4:16 pm
yep, thanks for the heads up, they arrived and fitted, I should order a couple of the connectors and wire them myself to fit my heated vest and gloves
Mark Esposito
Postby Mark Esposito » Sat Apr 28, 2018 10:46 pm
I hadn't thought of that as a use for the starter pack ,good thinking !
While we are on the subject, lidl have a combined starter / compressor/ light / usb power out coming in on Sunday the 6th
For £60 with 3 year g'tee
Ultimate Speed Powerbank with Compressor
https://www.lidl.co.uk/cps/rde/www_lidl ... tryCode=GB
Mark
Postby george baker » Sun Apr 29, 2018 8:06 am
B*****r, I would have had that rather than the one I have to get the compressor
Mark Esposito
Postby Mark Esposito » Sun Apr 29, 2018 8:10 am
This is the first time I have seen this one, so it may not of been available when you got yours.
Mark
Mark Esposito
Postby Mark Esposito » Sun Oct 27, 2019 4:41 pm
This stick compressor is available at Lidl from Nov 10th £30 and a 3 year guarantee
Ultimate Speed Portable Compressor
https://www.lidl.co.uk/p/p26777?product ... tryCode=GB
Mark
Sent from my motorola one vision using Tapatalk
Postby george baker » Tue Oct 29, 2019 6:59 pm
if it had a USB outlet I would be buying it
Users browsing this forum: No registered users and 12 guests
