RT Lower fairing bracket insert repair.
Postby CaptAirhead » Tue May 29, 2018 10:37 am
One of the bolts on the lower fairing bracket had seized with the result that the brass insert pulled out of the housing. Even in the vice the nut would not budge so will have to be cut off. That just leaves an empty hole in the fairing where an insert should be:-
ImageBMW R80/7 TIC lower fairing bracket repair. by Ian Beat, on Flickr
A wee scout around eBay and I found some press-in inserts of the correct size so I tooled up for a repair:-
ImageBMW R80/7 TIC fairing bracket insert repair kit. by Ian Beat, on Flickr
I worked on the hole a wee bit with a round file to get the diameter correct. Didn't want the hole too small and split the housing or too loose so it would just pull out. I got a good press fit and with a drop of Araldite got the insert nicely bedded in.
ImageBMW R80/7 TIC lower fairing bracket insert repair. by Ian Beat, on Flickr
All I have to do now is cut the old nut off the bracket and we are good to go. Just have to remember to use a bit of copper grease and not over tighten the nut.
Another wee job done.
P.S. I might do the same thing in the instrument housing where some of the insert housings have cracked off with age.
Re: RT Lower fairing bracket insert repair.
Postby gogs01 » Tue May 29, 2018 1:43 pm
Too good to call a bodge - that looks like a good engineered solution ! :smile:
Postby Rob Frankhamr » Fri Jun 01, 2018 7:17 pm
B*gga!!
When I did it, I actually made inserts by filing down nuts. Never thought to look for inserts on ebay!
Postby gogs01 » Sat Jun 02, 2018 12:02 pm
..... When I did it, I actually made inserts by filing down nuts .....
Good therapy ? :grin:
Mark Esposito
Postby Mark Esposito » Sun Jun 03, 2018 8:50 pm
Could we have a link to the inserts you used for future reference.
Thanks,
Mark
Sent from my VFD 710 using Tapatalk
I have 1985 BMW R80 RT monolever & a 1988 R80 RT in case i forget to mention it when asking a question !
Postby CaptAirhead » Sun Jun 03, 2018 10:04 pm
These are the inserts I used:-
https://www.ebay.com/itm/THREADED-BRASS ... 2749.l2649
Size: M6 x 7.7mm
Mark Esposito
Postby Mark Esposito » Sun Jun 03, 2018 10:05 pm
Size: M6 x 7.7mm
Thanks Ian.
Mark
Postby DEEP DIVER » Fri Jun 22, 2018 2:40 pm
Its a technical repair. :smile:
