Mirrors
The new BM Riders Club Forum - OPEN TO ALL
Forum rules
carlandpatsie
Mirrors
Postby carlandpatsie » Fri May 05, 2017 6:40 pm
Riding home last night r/h mirror indicator housing fell off smashed to bits any ideas where to find replacement bmw r1100 rtf 1998
Re: Mirrors
Postby Galactic Greyhound » Fri May 05, 2017 7:08 pm
Used parts available from:
Motorworks
James Sherlock
New parts from:
Motorworks
Motobins
James Sherlock
BMW Dealer
Consider using a long cable tie to loosely retain the Mirror Assembly should it become detached again.
You want it to detach if struck but not to fall onto the road.
The Mirror Glass can be replaced separately but it sounds like yours is beyond this.
Check that the three fixing pins that mate with the Mirror pod are not damaged - I like to put a smear of copper grease on these pins.
Also check when fixing the pod that the clip fingers on the pod do not get damaged as this can cause the pod to detach when riding.
Align the three pins with the clip fingers when fitting then strike the pod with the heel of your hand onto the pins front first then the rear two.
Check it is secure.
carlandpatsie
Re: Mirrors
Postby carlandpatsie » Sat May 06, 2017 7:29 am
Thanks I have tried most of the places suggested. Will use cable ties next time
alexis291
Re: Mirrors
Postby alexis291 » Sat May 06, 2017 8:02 am
You can get glass cut to size here http://www.carwingmirrors.co.uk/custom- ... irror.aspx.
I paid half of the cost of a BMW mirror and the quality is good. They do flat or convex. I drew round my other mirror to send them the shape. Glued the new one onto the remains of the broken mirror with silicone.
Return to “BM Riders Club”
