Metric Bolt Torque Table Nm
Postby Galactic Greyhound » Sun Oct 03, 2010 3:29 pm
Hi folks,
If you use a torque wrench and have ever wondered how much to safely tighten a bolt, or whether the torque setting given in the manual is a typo error then here is a link to a handy printable Metric Bolt Torque Table covering 8.8 Hex head, 10.9 Hex head bolts and 12.9 Socket Head cap Screws:
http://www.cncexpo.com/MetricBoltTorqueNm.aspx" onclick="window.open(this.href);return false;
IMPORTANT These figures are the safe clamping torque for a given bolt before it will break - they are not the torques to be used if the bolt is threaded into anything other than a materially equivalent steel nut or suitably threaded steel hole. If the bolts are threaded into alloy, aluminium or any other less strong material then a lower torque must be used to avoid stripping out the threads - see the manufacturers manual for the appropriate torque values to use.
Thanks to CNCexpo.com for the data.
Return to “Tricks 'n' Tips..”
