Alternative tanks fro an R80
Ask your questions re Choppers, Bobbers, Trikes etc here
alexxx
Country of Residence: UK Edinburgh
Postby alexxx » Fri Nov 01, 2019 5:37 pm
Looking to fit an alternative tank to an R80 as I am considering a scrambler build.
Has anyone used a tank that has been an easy unit to modify and fit?
Re: Alternative tanks fro an R80
Postby george baker » Fri Nov 01, 2019 6:50 pm
No but consider the basic/kalahri ones
alexxx
Postby alexxx » Thu Nov 14, 2019 5:46 pm
Postby Rob Frankhamr » Sun Nov 17, 2019 5:37 pm
There are three basic styles of tank that can be fitted without any serious modification... The 18 litre small tank, the 22 litre large tank (both from the /5-/6 models) and the 24 litre tank already fitted. Not sure how easy it would be to fit a 'GS tank or a R45/R65 tank. The main issue with any of the tanks is clearance for items fitted under the tank (relays, ignition modules, connectors & etc.) but these could probably be relocated. The best bet would be to decide which tank you like, source it and see what mods are needed to fit it.
alexxx
Postby alexxx » Fri Feb 14, 2020 2:27 pm
Thanks Rob
Now thinking to keep the original tank respray in blue (original colour) use some colour technique to disguise some of the tank depth.
Return to “Choppers, Bobbers, Trikes & other strange types Q&A's”
