iABS problems R1200RT
mrtg
Postby mrtg » Fri Aug 10, 2018 8:46 pm
I’m new to forum and wonder if anyone might be able to help me, I have a 2005 r1200rt with an abs issue, the original fault was the abs releasing under heavy braking (the wheels weren’t locking) and the brake fault light flashing after. Since then I’ve totally flushed and bled the system (all 4 circuits) just test rode it, bike seems ok until you apply very heavy braking on rear circuit then fault light comes on and servo stops whining (rear circuit only) front seems fine. Bike resets when power turned off, seems ok until heavy braking re-applied to rear.
I’ve invested in an elm327 reader and motoscan software, however fault code given means nothing to me (wheel circuit rear code 618c) anyone any ideas, suggestions?
Thanks in advance Tony
kent_instructor10
Country of Residence: Kent, UK
Re: iABS problems R1200RT
Postby kent_instructor10 » Fri Aug 10, 2018 11:58 pm
I believe that fault code indicates that the brakes have moved to residual braking, which would indicate a problem with the servo system, which sounds correct from your symptoms.
Im sure more technically able members will be able to assist further.
Now: 2013 R1200RT SE; 2012 R1200GS Triple Black; Previously: K1100RS, R1200RTPx2, R1100RTPx2, R1100RT, R80RT, K100LT and Jap stuff!
http://www.invictamotorcycletraining.co.uk
goldenoldy
Postby goldenoldy » Sat Aug 11, 2018 7:28 am
Hi Tony. Same model as mine. What sequence are the lights flashing at? Sounds the same as mine, first the rear then the front failed. For me the way forward was to have the system removed. Leaving me with conventional braking which is excellent. Roy Gardner did mine. Made no difference to insurance or MOT.
mrtg
Postby mrtg » Sat Aug 11, 2018 8:43 am
Thanks Brian, bike seems ok with normal braking, however when I force rear abs to cut in, I get red warning triangle and brake failure light rapidly flashing, book states one circuit in residual braking mode, other thing is rear servo stops working till reset with key. Was thinking same as you regarding removing abs as I like riding the bike, very interesting regarding insurance mind.
Thanks Tony
Postby Mike D » Sat Aug 11, 2018 11:09 am
Maybe you have not bled all the air out of the rear systems. I assume your code reader does not have the function that a GS-911 has, in that there is a test to check if you have evacuated all the air from the system.
MIke
mrtg
Postby mrtg » Sat Aug 11, 2018 6:10 pm
Thanks Mike
Don’t think it does on my type of bike but will check
Tony
mrtg
Postby mrtg » Thu Aug 30, 2018 5:38 pm
Hi there
Have worked through responses, have bled rear circuits both control and wheel until I’m certain no air is present, checked gaps and clearances, cables etc can’t find anything untoward. Took bike for another test ride, deliberately didn’t try to activate abs, after 30 mins of riding stopped at T junction holding bike on rear brake, as I pulled away noticed 4hz flashing brake failure light and red warning triangle on. I’ve contacted motoscan about the fault code that’s appeared again (rear brake circuit 618c) there response was they have no further information and to contact BMW, loads of help, would suggest others maybe think twice about this software as the support so far has left me cold.
Anyway upshot is I’m thinking of removing the iABS, happy with how this is done, direct link brakes and remove ecu from abs and reconnect electrics, my question is what’s the latest and best way of stopping brake failure light and red warning triangle illuminating, my bikes an RT with canbus, so if anyone’s aware of a better method than masking the indication would appreciate it.
Thanks Tony
goldenoldy
Postby goldenoldy » Thu Aug 30, 2018 7:12 pm
Hi. When Roy did mine he blanked them off internally on the dash.
mrtg
Postby mrtg » Thu Aug 30, 2018 7:25 pm
Thanks Brian, where’s Roy Gardener based,not anywhere Durham with my luck
goldenoldy
Postby goldenoldy » Thu Aug 30, 2018 7:31 pm
Just out of interest Tony, can you hear the hydraulic pump whine when you apply either then foot or hand lever? Mine went on the front first, I could still hear the pump, then went on the rear and the pump went silent. Roy is in Croston South of Preston.
mrtg
Postby mrtg » Thu Aug 30, 2018 7:45 pm
Cheers Brian, I can hear the servo when I apply either front or back brake before flashing brake failure light occurs, after that only from front, rear circuit has the issue. Both work again after switching off and on.
Tony
goldenoldy
Postby goldenoldy » Thu Aug 30, 2018 8:51 pm
Not an expert at all, but it sounds like the pump is ok. I have read of a duff battery causing issues. Even if it’s strong enough to start the bike it can cause abs/servo problems if it’s slightly down. Brian.
mrtg
Postby mrtg » Thu Aug 30, 2018 8:57 pm
Thought of that one, already replaced sadly :-( gut feeling is to remove at the minute, as I’m more worried it fails when I need it
Tony
mike pace
Country of Residence: England, UK
Postby mike pace » Mon Sep 03, 2018 5:37 pm
I have a 1200gs with the abs removed. No problems at all and stops well.
mrtg
Postby mrtg » Thu Jan 17, 2019 11:08 am
Decided to take the plunge and remove the system following lots of guidance available online, purchased necessary parts from motorworks (in the uk), re-used some parts of the original iABS metal work to make a good job of sealing the electrics and also providing an original mounting bolt and mount. High density foam sorted warning lights, so still have the amber warning triangle available for low fuel etc. Bike fine to ride and passed MOT with no issues, brakes still very good and I feel safer knowing that they’re there when I need them. Informed insurance company and they had no issues with mod.
To anyone else with same issue, it’s a big job but certainly not impossible and sooooo much safer.
Tony
PS borrowed a 911 and the fault code shown up earlier by non 911 unit, equated to a rear circuit failure in the iABS unit
goldenoldy
Postby goldenoldy » Thu Jan 17, 2019 2:52 pm
Well done Tony. It’s a great bike to ride and the fact you’ve been able to do it yourself is good. On my last Mot the tester didn’t seem to notice the difference till I mentioned it. I think they discontinued the part on or after 07 models.
