Recall all R1200GS & GS Adventure 11/2013-06/2017
ffbikersa
Country of Residence: Bosnia-Herzegovina
Postby ffbikersa » Fri Aug 11, 2017 4:34 pm
According to German magazine MOTORRAD issu no. 15 from July 7th, there is a worldwide recall for all R 1200 GS and GS Adventure made between November 2013 and June 2017, due to the problems with piece closing Telelever stanchions. It already caused several accidents, including this South African owner who created a separate web site "BMW Fatal Flaw":
http://bmwfatalflaw.com/
Re: Recall all R1200GS & GS Adventure 11/2013-06/2017
Postby King Herald » Fri Aug 11, 2017 6:16 pm
Sounds like it took a while but BMW have conceded defeat at denying fault and have accepted responsibility.
Scary stuff, if your front end falls off at speed.
R1100R
Suzuki Bandit 1200
Postby george baker » Fri Aug 11, 2017 6:31 pm
http://www.vosa.gov.uk/vosa/apps/recall ... tring=(BMW MOTORCYCLES R SERIES) for the date range 01/1/1992 to 01/1/2020&tx=0.7775843
is the DVLA recall pages for BMW motorcycles, but I can not find a new recall.
ffbikersa
Postby ffbikersa » Fri Aug 11, 2017 7:30 pm
The BMW press agent Mr Gerhard Lindner in the interview on page 2 commented on so-called "service action" "Check the stanchion" - which they are performing for all R 1200 GS and GS Adventure worldwide being produced between November 2013 and June 2017. So it may not be CALLED a recall - but it IS a recall. The main text say how if the measured distance between piece that is closing the stanchions on top is 0.1 mm, the add the securing bushing, and if it is 0.2 mm or more they replace the existing stanchion with a new one, which already has the securing bushing.
British motorcyle press (Motorcycle News etc) also reported on this...
http://www.motorcyclenews.com/news/2017 ... uspension/
https://www.bennetts.co.uk/bikesocial/n ... ety-recall
And US as well
http://www.advpulse.com/adv-bikes/bmw-r ... on-recall/
https://ultimatemotorcycling.com/2017/0 ... -affected/
Always felt sorry they replaced lovely good ol' 2-valve "boxer" bikes with this overtechnologised, overpriced crap - and it's just showing it's true face.
Tarik
Sarajevo, Bosnia
ffbikersa
Postby ffbikersa » Fri Aug 11, 2017 8:18 pm
on US pages:
UPDATE:
WASHINGTON, D.C. – July 25, 2017 – Fork Tube may Detach From Upper Triple Clamp
If the fork tube detaches from the sealing plug, the handling and stability of the motorcycle will be affected, increasing the risk of a crash.
NHTSA Campaign Number: 17V438000
Manufacturer: BMW of North America, LLC
Components: SUSPENSION
Potential Number of Units Affected: 14,626
Make Model Model Year(s)
BMW R1200 GS 2014 – 2017
BMW R1200 GS ADVENTURE 2014 – 2017
Summary: BMW of North America, LLC (BMW) is recalling certain 2014-2017 BMW R1200GS and BMW R1200GS Adventure motorcycles. The motorcycle fixed fork tube may separate from the pressed in seal plug that secures the tube to the upper triple clamp.
Remedy: BMW will notify owners, and dealers will add an additional fixed fork tube bush. A fork that is sufficiently damaged will be replaced with a modified new part. These repairs will be made free of charge. The recall is expected to begin September 1, 2017. Owners may contact BMW customer service at 1-800-525-7417.
Notes: Owners may also contact the National Highway Traffic Safety Administration Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153), or go to www.safercar.gov.
TR80
Postby TR80 » Mon Aug 21, 2017 12:59 pm
I've had the recall.
Spoke to dealer who told me the reinforcing parts aren't even in the country but they are glad to check it out if I take the bike to them. They had looked at a few (including his own machine) and not found any with play.
He understood it needs a really brutal knock to start the play, same kind of force to buckle a wheel!
He said the steering then suffers / clonks and oil may leak long before the forks collapse. Means most riders would spot the problem long before it all fell apart.
I checked mine for the .02mm gap with feelers and no sign but will call in for them to properly check - " takes 10 mins".
There's a good video link from 'Bennets insurance' site to see how to inspect the problem area yourself..
In the meantime I'll avoid climbing over boulders and tree trunks with the 'bike......
Postby Galactic Greyhound » Sun Jul 22, 2018 12:19 pm
