Exhaust flap problems
Mark Esposito
Postby Mark Esposito » Wed Jun 16, 2021 2:25 pm
Background video
https://youtu.be/qFFuICIEZz0
Current video and call to arms !
https://youtu.be/LCiw3xcq9Oo
This appears to be a common problem, in fact I seem to remember the missenden flying doing a review of the WiFi diagnostic tool and this fault came up on his bike.
Mark
Sent from my motorola one vision using Tapatalk
I have a 1988 R80 RT monolever in case i forget to mention it when asking a question ! and I'm based in South Wales
Re: Exhaust flap problems
Postby DEEP DIVER » Wed Jun 16, 2021 9:31 pm
Good point Mark. Any exhaust system with a pivot flap system will give trouble as it heats up and cools down. If the pivot was greased the grease would run off with the heat. It would be better to remove it completely.
1985 R80RT Touring dream sold
Mark Esposito
Postby Mark Esposito » Wed Jun 16, 2021 9:35 pm
Unfortunately I think if the flap was removed some kind delete in the ECU may be required.
Mark
Postby Mjolinor » Wed Jun 16, 2021 10:13 pm
Any exhaust flap you have for whatever reason like variable vane turbo or whatever needs this:
https://www.ebay.co.uk/itm/265140480222 ... Swa9dgiShq
It will never stick or wear again.
I don't know the specifics of the guys problem but if it is related to pivots, bearing surfaces or whatever at exhaust temperatures then graphite powder will lubricate it and it will stay lubricated.
Postby Mike D » Thu Jun 17, 2021 12:16 am
Not true. there will be fault recorded, but nothing that will prevent the bike from running.
Mark Esposito
Postby Mark Esposito » Thu Jun 17, 2021 12:21 am
The guy in the video says it brings up a engine warning light, I wouldn't want to ride around with a warning light on in case another fault arose and i couldn't tell as the warning light was already on .
Mark
Mark Esposito
Postby Mark Esposito » Sat Jun 19, 2021 11:36 pm
Latest video,
https://youtu.be/4mWn_BBnexM
Can't see how a software update will cure a seized exhaust flap unless they switch off working ones in the open position before they seize.
Mark
Jockboxer
Postby Jockboxer » Sun Jun 20, 2021 7:18 pm
The main problem here is that the LC 1250 flappy valve is integrated into the manifold? The 1200s were easier (and cheaper) to fix!
https://www.realoem.com/bmw/enUS/showpa ... Id=18_1505
